96 Model C With a Short somewhere
hage1
I am a homeowner and this machine (96 Walker Model C)has served us well. It worked fine last week. I tried to start it today and noticed an electrical burning smell. The ground cable, which was old, burned thru. I replaced the cable and tried again. The ground wire and battery heat up, so I'm guessing a short somewhere. The engine does not turn over or make any noise at all. The only Walker dealer within 100 miles closed a few years ago, and I've managed to keep this thing going on my own with help from forums like this. Where would you suggest I start looking? Any suggestions are greatly appreciated.
are they heating up just sitting, or only when it is running?
Thanks for the reply. My neighbor, turns out to be "the man" for engines came over to see what I was fusing about. He tested the starter with a screwdriver and it works fine. He noticed a hole in the red cover on the battery terminal and suspects it was shorting out to the frame. Maybe 30 years of my fat arse pushed the frame down a bit. Anyway it is up and running after some flex tape here and there. and I got the grass cut before the rain. We'll see next week! Thanks again.
An IR camera will show you immediately where the issue is. Poor corroded connections show up as heat.
I do blow the engine clean every use, but didn't know about the engine shroud. That will happen before the next use. Thanks!
