R rickrichardson519 Member Joined Jun 20, 2018 Messages 10 Sep 17, 2018 #1 no hydro fluid pumping yes has fluid
BlazNT Lawn Pro Joined Apr 26, 2012 Messages 6,973 Sep 18, 2018 #2 How do you know no fluid is pumping?
H Hitechluddite Well-Known Member Joined Dec 14, 2018 Messages 100 Jun 9, 2019 #3 rickrichardson519 said: no hydro fluid pumping yes has fluid Click to expand... I think that if the bypass lever under the seat is lifted the pump does not pump....
K kenora Forum Newbie Joined Jun 12, 2019 Messages 1 Jun 12, 2019 #4 the by-pass MUST be in the RAISED position to get the tractor moving.... depress it if you need to tow the tractor
