Model 192432
type 1219 E1
code 0001121B
walbro carbureto , LMT 5-4993
this engine is on a Troy belt rear tine tiller.
symtoms- had to run with choke partially on.
took carb off, had to run a left hand threaded bit to get the main jet? (Or whatever it’s called) out. Previous owner boogered the slot.
cleaned good, assembled, started up and now it runs rich, black smoke, finally will settle in and idle, engage tines and black smoke blows out and will almost die.
gas is misting out of the carb while it is trying to run
Float and needle seem to be working when I blow into the fuel inlet,
any ideas?
type 1219 E1
code 0001121B
any ideas?
