8 HP kohler valve spring question
brizjuan
I recently started restoring my 67' 110 with an 8 hp kohler motor... When I took the valves out the parts got all jumbled together and now I can't remember which spring goes with which valve... One of the springs is longer than the other... I'm thinking the shorter one is for the intake valve? Also one of the valves had that little bearing looking retainer to keep it in place.. N e ideas which valve that goes with as well... Thanx
Go to the Kohler website to search for your specific model and download the service manual for your engine, this may help you.
[URL="http://kohlerengines.com
