8 hp bs engine will not run except on full choke
rick pascal
the engine will cut off if i take it off of full choke
Sounds to me like it's time for a good carb cleaning or rebuild. Can you post the engine numbers so we know what you are talking about. We don't know if it's a Briggs, Kohler or a small block Chevy. Sorry missed the bs.
rick pascal
yes it is a briggs 8hp about 12 years old. it currently is on a snapper riding mower.
Need to know engine numbers. Don't know if you have an adjustable or nonadjustable carb.
rick pascal
at 3600 r 8 horse power
rick pascal
chance123
It's necessary to have the model, type, and code this is usually (on an overhead valve engine) on the valve cover, or on the shroud that covers the flywheel.
