75754 transaxel mounting fastener torque.
cliffblue
Looking through the manuals I have down loaded and printed, I’m not finding the torque for the fasteners that secure the transaxels. I’ve noticed one loose enough that you could see there had been movement. I snugged it up and checked the others. If someone could direct me to where I could find them, I would appreciate it. TIA, Clifff
Install, but do not tighten, the 4 (1/2 inch) bolts and nuts, 3 (5/8 inch) bolts,
and 11/16 inch nut securing the transaxle to the chassis. See torque
sequence below.
A. Torque the (5/8 inch) front inner mounting bolt and (11/16 inch) nut to the
frame bracket to 67.5–74.5 N • m (50–55 ft-lb).
B. Torque the 2 (5/8 inch) bottom mounting bolts and (11/16 inch) nuts to
the cross plate to 67.5–74.5 N • m (50–55 ft-lb).
C. Torque the 2 (1/2 inch) front and rear mid-mounting bolts and nuts to the
chassis to 22.5–25 N • m (200–225 in-lb).
D. Torque the 2 (1/2 inch) axle mounting bolts and nuts to the frame bracket
Install the motion control linkage. Install the ½ nut and 5/8 bolt securing the
motion control linkage to the transaxle. Torque nut and bolt to 22.5–25 N
Install the 13/16 inch lug nut securing the wheel to the transaxle hub. Torque
lug nut to 94.5–122 N • m (70–90 ft-lb).
Service manual will most of the other questions.
cliffblue
sequence below.
Thank you for taking the time to write this out.
Just cut and paste from the SM.
