Has anybody had to change this? If so is it tough and how long did yours last? I have 325hrs and dont have a problem, but just curious what I am in for when/if it decides to go out. I have the T6 drive system
they tend to last a long time if installed right, it should slide easy in and out between the two metal spline hubs. using shims under the engine to get proper alignment.
