725EXI Sump Replacement. Please Help
lonzo2003
I own a Husqvarna HU 725AWDH and the previous owner hit a stump with it and the shear pin didn't break but it did snap the sump and I have been trying to find the specific part and I have had no luck. I would really appreciate any help. Thanks
We are going to need the model number of the engine to assist you. If one of the newer briggs engines the model number should be engraved into the side of the block behind the muffler.
lonzo2003
Thank you I have been trying to figure out where the number is.
Mkala
Help to find your model number :
Are you sure the crank is not bent with a broken sump ?
When you got the numbers you can have the owner manual and the Illustrated Part List to search your part with B&S part number :
