721D Steering lever doesn't return to Neutral
gh8165
I've got the right steering lever that doesn't want to return to neutral position when you let go of it. The left will return but it's slow. I've looked for the grease qirks that were mentioned in earlier poast but I've not found them. Any other suggestions. The manual doesn't go into details about this. Suggestions or pictures would help me out.
flip your seat up and look above your drive wheels or move your steering lever and follow it back to the vicinity above the tire and you should see a zerk...russ
Hi GH8165
Yes i think you need to do some adjustment on the level there, you might have to call a John Deer dealer and see if they will tell you how over the phone or take it in and have them adjust it. Tell them your manual doesn't show how and maybe you could get one of there manuals that tells how to adjust. Maybe online you could find a better manual . Good luck just some ideas:licking:
