7 hp snowblower Carb question
bigtdog
I am looking for a carb to replace mine on my 7hp snowblower.( h70 1302) The number on carb is 143 which references a a service part number of 631159.
Can't find anything under that service number. Is there a replacement carb for it.
Russ2251
A rebuild may be your only option.
Tecumseh diaphragm carbs are exceedingly difficult to come by.
It is possible to put a bowl style carb on there, that has been done many times .......... You will have to do some research though... Bolt pattern should be a match.... Room for the bowl carb ?? A 8hp genny carb should fit on there.....
Let us know Mon Ami ~!~!
