62" Z beast
Jdbob
Anybody else dumb enough to buy one like me nothing but problems ! One year paint pealing cylinoid went ignition switch replaced wheel was left loose cant tighten lug nutts . Now the right side drive not operating properly turn circles one way just now have 40 hours !
If you purchased it new all those things should be covered under warranty.
Jdbob
Everything was covered under warranty but the tire they say had a 90 day warranty. The problem is it was left loose by factory and the holes are in large and the lug nutts wont tighten. They're telling me its 259.00 us dollars. I've found out if I turn the tire around I can tighten the lug nutts but if I ever need air I have to remove the tire .
