616 deck raising
I have the manual lift deck on my old 616 mower. I've looked at video of raising the deck to access the blades, and my machine does not match those I've found to look at. My lift arm for setting mowing height does not fold down next to the deck. Must I pull the pins and move the mower away from the machine in order to raise it to access the blades?
What's the procedure for removing the drive shaft end? I've tried to pull out the sleeve to get it to release, but sleeve will not move.
