61 inch ICD Mulch Kit
Wadejesu
If anyone has installed one please post your thoughts, criticisms, How is it in tall grass, wet grass, etc. I haven't spent the 300+ yet.
Thanks in advance.
MParr
In tall or wet grass, you will get better results with high lift blades and side discharge.
hlw49
All I haver ever seen mulching kits do is clog up under the deck and leave big ball of grass in the yard. The problem is no one slows down when they mulch. Might help the problem. Mow more often and don't cut more than 1/3 the height of the grass
hlw49
Snapper use to make a mulching kit for their rear engine rider and it limited the speed of the mower by blocking the shifter so you could not shift into any speed past third I think it was.
Skippydiesel
No mulching kit is worth the money - with the exception of people who mow their lawn, at very short/frequent interval, mower mulching kits/systems, are a marketing con.
