Fireman8811
- Apr 5, 2018
- 1
- 1
My mower won't start with the key. If I turn the key to on position and jumper the positive terminal from the starter to the blue wire on the solenoid it will turn over and start.
I have a new battery and starter. I have 12.5 to the starter terminal. When I turn the key on I can hear the fuel pump prime. I can also here one of the three relays kicking. I have no voltage to the blue wire going to the solenoid when I turn the key. Not sure where to go at this point!
It has the 28 HP Kohler engin in it. Please any help would be much appreciated!
Thanks TJ
Thanks TJ
