If both deck locator rods are broken will it cause deck belt and deck spindles/pulleys to make an unusual squealing sound and slow engagement of the spindles/blades? I just discovered the rods were broken at the front welds when I noticed the noise and the slow engagement. Our one granddaughter mowed our grass (18 acres) while we were gone for two weeks and I don't know if she hit some tree roots or large landscaping rocks,or cement seawall. Or, perhaps over time, they could have gotten weakened from use by my wife or myself. I surmise the squealing may be from the belt slipping and slow engagement also from slipping. When adjusting the deck belt tension should it be done with the deck height set at 1 -1/2 inches and the belt then being tight or loose? When tightening the drive belt does it make a difference what the deck height is? I read that a credit card thickness (.030) should be between the spring coils. Does this also apply to the tension spring on the deck? My thanks to anyone with information fo me.
