H hrdman2luv Well-Known Member Feb 5, 2018 #1 Chipper bit the dust. Needing a 5hp briggs, with a straight 1" horizontal shaft. It connects directly to the wood chipper. It's not threaded or tapered.
M mechanic mark Lawn Pro Feb 15, 2018 #2 https://www.google.com/search?q=b&s....69i57j0l5.20333j0j8&sourceid=chrome&ie=UTF-8 you will need all information from data plate on blown engine to match for correct replacement engine
Boobala Lawn Pro Feb 16, 2018 #3 IF Mark's link does not help, here's a few others... https://www.briggsandstratton.com/na/en_us/support/faqs/browse/direct-replacement-engine.html http://www.smallenginewarehouse.com/ https://www.smallenginesuppliers.com/ Good Luck in your quest !!
