jsflynn603
- Jul 7, 2012
- 1
- 4
Many years ago I rescued a Sarlow 24" self-propelled mower from the dump. The mower blade shaft/bearing was gone, and the engine appeared seized, but it wasn't... some patience, $60 for a bearing assemply and Marvel mystery oil in short order it was up and running has been for over 5 years now.
It runs beautifully, often starting on the first pull but lately it's been doing something odd, it's cycling rpm-wise, high, low, high low... On the carb there is something that has two springs and whatever that is is moving back and forth at about a two second cycle. Worse, it causes the pull rope to somehow get stuck and start to screech. (Note: Recently it was doing this, so I took it apart and cleaned off the small balls and did NOT lubricate, so this seems odd--the balls were free wheeling two weeks ago.
I'd love to simply buy a new carb but I doubt that is possible. Perhaps someone can give me an idea, why there are two springs (one very thin, and one thicker) what attaches to the thing that moves back and forth. Even with a hint, I probably can fix it.
The engine is model 131782 type 3125-01, vertical shaft with a PTO--so very expensive to simply replace. The Sarlo hi-wheel is a real workhorse, and I use it to mow 1+ acre of fairly rough lawn.
Perhaps someone can point me in a direction that explains what that connector to the carb does, how it works...?
Any ideas would be greatly appreciated.
Btw...the carb is totally cleaned--no gunk or varnish in it.
Thanks,
Steve
Thanks,
Steve
