550 Series 158cc B&S motor 10T800 series
For the people trying to figure out why the motor starts if you add gas to the carb, make sure when you flush the tank you clean the carb bowl that is made into the gas tank and make sure the two nozzle in the tank but part of the fuel pick up is clean, and after I mount the tank, fill the carb bowl. after a week my brain started working agai n, hope it the fix, thanks
