Ric
- May 7, 2010
- 5,765
Agreed ^, the fan inside makes the blower , the more efficient the fan setup the harder they blow w/ the power they have. If they all used the same fan setup more CC's would matter.
Sometimes they are very close and for all intents and purposes the larger ones are VERY close in CFM. Sometimes it comes down to people choices ergonomics , fit, weight , what they use it for exactly - etc......even companies you trust.
I also like to think warranties matter and dealer service matters- everything needs to be thought about when you spend 3-4-5-6 hundred beans. JMO-
Note: there is no testing facility they send them to , that I'm aware of ...independent one. So numbers are just that test them for yourself , I was surprised.
Yes I would agree that if they all used the same fan, motor size would matter but they don't that's the reason CFM is so important when buying a blower. If you use Stihl as an example, there top three blowers the BR 500/ 477cfm, 550/ 530cfm and 600/712cfm all have different CFM ratings with and without the tubes, one rating taken at the housing, one at the tube but all three units run the same 64.8cc engine that's why I say engine size really doesn't or shouldn't play a big part in purchasing a blower. The engine thing is more for longevity than anything else. I also agree with you about it sometimes comes down to choices fit, weight etc. and a company's trust, warranty and service are big ones for me that's why everything I buy is Stihl.
