x540
- May 19, 2018
- 16
Hey guys, I am going to replace the belt on my 44" snowblower, Is there any tips / known procedure in doing this so I dont end up having to taking everything apart ?
EDIT: Well I went and replaced it, It wasnt bad as I thought. All I had to do was remove the plate were the pullies are bolted to ( 4 bolts, 2 on each side ) in order to get the belt off of the large main pully and just loosen up the small pullies enough so the belt could sneak by the guards... Was very easy I would say. Hope that helps anyone wanting to know how to do it.
