Comr @ AGT
- Mar 28, 2020
- 2
- 2
This 2 wheel steer 1996? 425 has a very bad leak on the left side of trans. I believe the linkage pin that control the differential lock mechanism is what's leaking. Does this require removing trans to change out o-ring or seal ? The deck lift cylinder is leaking also so when that is removed for replacement maybe there would be enough room to get at the o-ring..... any thoughts.
