Rover_Hokie
- Jun 20, 2013
- 1
- 1
I have replaced the two-blade system of riding mower blades before, but maybe I am just OCD now in my old age. I searched and watched some videos on YouTube, and searched the forum, but there seems to be no real rhyme or reason as to how the blades are positioned in relation to each other as they go around when the blades are installed. Example: When re-installing blades should one be installed at the 12 o'clock to 6 o'clock position while the other is installed 90 degrees to it pointing from 9 o'clock to 3 o'clock, or does it matter at all when the blades are rotating when mowing?
