J jlwoods99 Member Joined Aug 7, 2026 Messages 19 Aug 8, 2026 #1 I'm missing something, my transmission as I'm mowing increases speed. I start at slow speed and the lever creeps to faster and faster speed. What should I be looking at? Jim
StarTech Lawn Royalty Community Leader Joined Feb 19, 2020 Messages 14,534 Location Pluto Aug 9, 2026 #2 At replacing the lever as it sounds like the detents are badly worn.
J jlwoods99 Member Joined Aug 7, 2026 Messages 19 Aug 12, 2026 #3 StarTech said: At replacing the lever as it sounds like the detents are badly worn. Click to expand... Turns out when I disassembled it the spring steel that engaged the detents was broken. So thank you!
