Mad Mackie
- Jul 11, 2011
- 1,851
Hi Troops,
I finally got around to doing some servicing on my Tiger Cub. This is my first time leveling the deck and it took me 4 hours. The owners manual covers the basics however I had to get a little creative to level the deck side to side and then the fore and aft leveling was easy. I set the deck to the specs in the up and locked position and I was surprised to see that the blade height was 1/2" lower than the calibration on the height adjustment. Anyway I also replaced the deck drive belt and the vibration that I had been feeling while mowing went away. The belt had a few chunks missing from it which probably were causing the vibs that I noticed. I also checked the clutch gap which was still within spec. I had plans to replace the pump drive belt and idler pulleys, but the belt looked good and I had lubed the pulley bearings and replaced the collection blower bearings 50 hours ago.
Later!
Later!
