Hi, It starts up on first pull, runs at proper RPM without variance, but dies after about 10 minutes. Wait 10 minutes and it starts up again. It MAY be doing this in hotter weather (75 deg plus) and not in cooler weather, but I haven't checked that out closely enough yet.
This engine built around 1992, type with carb that mounts directly onto the fuel tank (no carb bowl).
Thanks for your help, Steve
