3204 cub cadet
dananfitz
Is it a good idea to buy an old 3204? Itseems to be in good shape. 550 hours on it. any input will be appreciated.
benski
That 800 lb. piece of machinery should treat you well if it has been well treated in its past. It is only about ten years old. Check it out while running, and change out all your fluids and filters when you get it hoe, unless there are service records with it.:thumbsup:
