Hello
Just joined so first post looking for some info/knowledge that im unable to locate....Pics inlcuded
Heres my issue:
You see the pics, im having trouble as to the valve guides and how they are set....Do they look proper how they look? Yes hard but thats why I need some knowledge as my first rebuild....
I bought the mower off the road, had bad carb, bent aluminum rod, needed a couple gaskets. Replaced all (though they did give me a steel rod so I am going to fix that no biggie) and engine fired right off, strong, ran then threw rod but no bend this time. Wash rinse repeat so now I have apart again to replace rod with aluminum to see if that stops it but I wanted to make sure all was right.
The exhaust valve sticks slightly, can I just lube and use if guides are ok? Very tiny bit of play side to side, I dont think enough to worry about, but should I? Springs and rest of items look fine to almost if not new/replaced and I do know this beast runs fantastic. Just must resolve head...Thankks in advance!
Kevin in Maryland
Heres my issue:
Kevin in Maryland
