Generac and Stratton
- Sep 3, 2019
- 8
- 33
Just wondering what full upgrade options I have for my 312-8, and how much of the steering linkage needs to be swapped at the same time? Like, is a 520H front axle + tie rods a direct swap? Anything with a roller or ball bearings on the spindles to reduce turning friction?
Trying to plan ahead in case I snap or bend my 3/4" spindles or have future issues with the 3/4" hub rims (tractor with me on it, empty, is close to 1200 pounds with full gas, ballast and scoop, and probably pushing 1500~ fully loaded).
There's a lawnmower "junk yard" not far from me, so I can probably get everything in one go from the same tractor, and if other brands are a direct swap or easily modified, include their model.
