290v smoking bad
jdogg
I have a John Deer RX75 with a 9hp Kawasaki motor. All of a sudden starting smoking white smoke. I noticed that the vent hose at the top of the valve cover has gas/oil coming out of it. Can anyone tell me what that means?? I am thinking rings?? Any help would be appreciated. Thanks in advance!!
shiftsuper175607
Check the oil level.
Carb float may have stuck open and drained gas into engine
jdogg
Oil level is good.
How would I tell if carb float is stuck open?? (sorry, I know absolutely nothing about small engines)
shiftsuper175607
Oil level is good.
do a search on "white smoke"
bertsmobile1 says in several posts it is oil burning and an indication of an internal engine problem...possible head gasket blown.
He is in Australia, so he may weigh in later.
shiftsuper175607
Did you turn the mower on it's side for any reason?
jdogg
I did not have it on its side at all.
