25 horse kawasaki blowing out oil
eigerogre
My JD 757 zero mower blows oil out of the dipstick hole .Tried a new dipstick,its still coming out and getting blown by the fan on the hot muffler?????????
KrashnKraka
This happen straight up, like no prexisting symptoms/anomalies?
Try fixing the stick in anyway you can then post up how the engine performs.
Only a short run at load, like two minutes max.
KK
eigerogre
This mower is 15 yrs old,lots of hours on it.Oil started last year or so.It starts coming out after running 5 mins or so.Enough to make noticeable smoke from the hot muffler,and dripping on ground.Is it time for engine work?....Is there a blocked pcv valve somewhere?
KrashnKraka
...ummmm, mostly logic built from the info so I can only offer
"pcv valve" may have collapsed, you could get that lucky at those
amount of hours. However you are reporting a heavily pressurised
c'case which would have had a working valve choking the carby feed,
long before this. I'd bet on a broken ring, or two.
Good news is,,, at that age you likely have a reasonable case to rebuild
or simply hone and replace with OS rings.
KK
eigerogre
Thanks,Will check for pcv.Where is it?
eigerogre
No pcv shown in manual on this v-twin kawi 25
gainestruk
Run a compression check on both cylinders, sounds like it might have a lot of blow by on piston rings from age, if compression is low and it still runs ok you might wrap something around top of dipstick where it goes into tube to make a tighter fit. That might get you thru season then rebuild or replace this fall
Hopefully some more will add ideas.
KrashnKraka
Yeup...thought as much.
Your engine was built long before the current PC crap began. As others suggest, try and keep it going - drive it till it dies - a thicker (weight) dino oil may help with blowby.
Just do not let it run low as that may well and truly ruin your case.
Good Luck an' go well.
KK
Mikel1
Is it also blowing oil out breather hose?
