24v48 ser 960450052
red423
I disassembled the pulleys for the drive belt and transition belt assy am going to reasemble when I can is there anything special I need to pay attention too? those spring loaded varible drives are just a take off of a modern torque converter used on numerous machines. the shaft that holds the pulleys? Are they a special setting to go back (No I didn't remove) I have a plan how to set trans belt to install cap plate on top of pulleys. And more info I may need. oled trans belt was shot and not turning trans.Thanks
