Hitechluddite
Last year I transferred a 2cyl 17HP Kawasaki motor from a LT190 over to a 245 that had the single cylinder 14HP kawasaki motor. I also moved over the wiring harness bypassing the seat sensor among others I put about 30hrs on it completely trouble free but a couple weeks ago with no warning it failed to start. Troubleshooting revealed no spark but wiring harness had no loose wires compared to previous running state. I got what was listed as an OEM switch with no key off ebay I got the switch, used my original key and it fired right up. It ran for about 2hrs then started running rough and hard to start. I found right plug wet but I had spark. I got to playing with the coil connections and giving the harness a closer look. This engine has a 3 prong ignitor, one prong goes to the coils, the other two back to the ignition switch. Strange thing is it would run with the ignitor wire to the coil disconnected. I know this is not right now after about 30 more minutes it will no longer run at all. I think I got a bad switch but running without the ignitor has me stumped and wondering if something different is going on.
