22hpbrigs moter np power
gjackson794
Moter misses no power could it need valves adjisted
Will need model numbers off engine to narrow down. Could be needs valve adjustment, could be bad spark plug, could be faulty ignition module. Could be a ground wire problem to a module. Could be poor compression on one cylinder. Could be a carb problem effecting fuel on one cylinder.
