Keith Murry
- Sep 15, 2025
- 2
First time poster and new to the group. Thanks in advance for any help you can throw my way.
I have a 2001 225 that has a factory replacement Kohler 27 hp engine. All was fine until the battery stopped charging. Tested battery and replaced it with a new Interstate. Still doesn’t charge. Changed out the voltage regulator and still no charge. Thought I may have plugged the voltage regulator in backwards so I bought a new one, plugged it in and now it won’t run unless the starter is engaged. I don’t know if I created a new problem or if this is all related. Any help would be appreciated.
