SEB-
- Aug 6, 2023
- 1
- 3
Toro 22 inch recycler model 20112 B&S 190cc 6.75.
Got this lawnmower wouldn’t start at all , cleaned main jet was plugged. So far I’ve cleaned carb multiple times , new air filter , spark plug . Checked automatic choke function and is working . Ran some sea foam through it as well.
When starting from cold starts fine , if I leave it running it will run forever no problem but if I shut it down sometimes it will start again very slow and puffs a bit of smoke but most times it won’t start at all until it cools down again .
Anything else it could be or to check ?
Thanks
Thanks
