cleaned carb new fuel lines new mags both plugs firing. only runs on one cylinder
removed valve covers and plugs and turned engine over and all rocker arms seemed to move the same
checked compression and is approx same when cranking engine. is he part on bottom of carb a fuel pump. it plugs in to a wire.
