EngineMan Lawn Addict Joined Jun 12, 2012 Messages 2,275 May 26, 2014 #11 rubantin said: ok.. took off the valve cover... bent rods.. figure it got too loose and came off.... can I just straighten them and put it back together? Russ Click to expand... It can be done, but its better to replace it.
EngineMan Lawn Addict Joined Jun 12, 2012 Messages 2,275 May 26, 2014 #12 rubantin said: The rocker bolt hole is stripped.... ugh!!! Click to expand... Unless you know a good man in engineering go for a replacement.
