2165 cub cadet start up
dpvasold
I have a 2165 twin 16hp. Only way to start tractor is bridge the solenoid, runs great. PTO or start switch does nothing. Have to have the key on and will shut it off.
Thinking relay or PTO switch. Need answer soon, weeds gettin high
packardv8
Wiring and switch problems are endemic to these machines. The key start and the safety switches which go through the brake, PTO, seat and reverse all failed on mine and caused problems similar to yours.
If others than you operate the machine, you may want to plan on a lot of regular troubleshooting and replacing the switches with original parts every few years.
JMHO, but because Im the only operator, now mine has all the switches removed, original wiring replaced and the PTO is a simple On-Off.
jack vines
dpvasold
jack vines
Forgot I posted here. What best way to buy pass the switches, jumper, unplug? My seat switch just un plugged one wire
