should be three nuts with springs behind them . you can adjust then . turn them a 1/4 of a turn in an try that . adjust it to your liking . do not go more than a 1/4 at a time . see if that helps you .you do not have to remove anything should be able to get to the nuts . it is a 9/16 socket
