21.5 Kaw FR engine gas usage per hour
7394
Just over a month ago I bought a new Toro ZTR SS4260 with a Kawasaki 21.5 FR engine in it..
First zero turn, & first V-twin mower engine. Just for use at my place, was curious to what other members might be using, gas wise per hour approx ?
I only use 100% gas, & only have 10.7 hours on this mower now. (also) Will gas usage improve as engine gets better broke-in ?
Appreciate any input.
PS: I tried using the "Search function" but couldn't find anything helpful.
Buddy
7394
Thanks Mark- I have the owners manual & read it cover to cover.. Just nothing in there about 'approx gas usage per hour' for this engine..
mechanic mark
Buddy, You purchased a nice piece of equipment, I'm sure your Kawasaki engine will serve you well. I would not be too concerned about hours per gallon as you may your personal vehicle. I use B&S fuel treatment & 93 octane gas in 5 gallon cans.
sjessen
My guess would be somewhere in the 1.0 to 1.25 gph range. This will depend on the mower's rpms and cutting conditions. Just to compare, I have a 23hp kawi (using the old ratings system) on a Turf Tracer and its fuel usage is in the range above.
7394
Thanks again Mark.. I am very pleased with this unit so far.. Was just wondering since I just got off a 20hp craftsman GT.. I now it's apples & oranges tho.
sjessen- Thank You, that is about what I am currently averaging, approx 1.0 gph... But as you mentioned, rpm's & conditions can vary results.. I'm ok with this.. Appreciate your input !!!
Buddy
gregjo1948
Your rpms shouldn't vary much because you should be running at full throttle. My FH680V (23hp) burns less than a gallon per hour and I mow some hilly ground and heavy grass/weeds. I use regular gas with no additives. gregjo1948
7394
Very true.. & Mine doesn't have 11 hours on it yet, so it is still not 'broken-in' ...
sjessen
I was referring to rpms at wot. The engine will use more fuel at 3600 vs say 3400 rpms.
7394
sjessen -
That's what I thought you meant..
PS: My mowing is now only taking 30 minutes, start to stop (dry weather) & using just less than 1/2 gal... :thumbsup:
