2026 Cub Cadet Ultima Z2 42
GFC
Not sure if this is a new Ultima model for Cub Cadet. I like the look and the price is right.
Auto Doc's
I don't deal with Facebook. Do you have an actual link that you can attach?
GFC
Auto Doc's
Hello G.,
That is bordering on commercial grade. How many acres do you plan to mow on a regular basis?
The pricing has climbed considerably in the past year (like everything else).
An important factor to consider is having a qualified dealer shop who can work on this if needed.
GFC
3 acres. I am 10 min from the nearest Cub service center.
Auto Doc's
Sounds like a good fit to me.
The only additional things I will mention is to use non-Ethanol fuel if it available or use a good mid-grade gasoline with a fuel stabilizer like Ethanol shield. Do not use the cheapest budget fuel you can find, it will cause nothing but problems in the long term.
If it has to sit for a period of time, make sure the tank is kept full to avoid evaporation sweat from collecting humidity in the air.
Of course, follow the oil change recommendations and plan on getting a battery tender/maintainer so the battery is kept at its peak condition. Mower batteries lose power and sulfate internally if left sitting without a maintainer. Most mower batteries only have a 6-month warranty but keeping them maintained is the key to a much longer battery life.
GFC
I use nothing but non Ethanol fuel in mowers plus Yamaha zuma 50. Also the person who services all my mowers, scooter (not a dealer) does not charge pickup or delivery fee. He is honest and charges far less than a dealer.
