2021 Club Car Precedent Kohler Ech 440-3018 won't start
Richard59
  • / 2021 Club Car Precedent Kohler Ech 440-3018 won't start
This 2021 Kohler Ech440 with Efi was running fine for a year and just stopped. Now it cranks but just floods with gas. Has 90 lbs compression and good blue spark. I'm stumped! Advice is appreciated!
Brad195900
If you have compression, spark and fuel you should start …. So try draining the gas, tank /carb and take fuel filter off and check for water or crap. I take the spark plug out and spin the engine to get rid of all fuel in there, refill with fresh gas and add sea foam. Check the air filter might be plugged. These are basic stuff, samething a shop wound do first.
Richard59
Mystery solved! The rocker arm tensioner nuts on the exhaust valve had backed off allowing the exhaust valve rocker arm to jump off of the push rod. Back in business! Thanks for the help!
