2018 Dixie Chopper Blackhawk HP 60"
Tatwo
Greetings to all,
Ripping along mowing like usual...suddenly all stop...I did not hit anything...system shutdown..."ERROR" on the display.
Turn off the PTO...pull up the E-brake...light on console goes green...so I start it up...I can drive it no problem.
Pull the PTO...it starts all over again with the shut down.
The deck is clear of obstructions and the belts and pully's all rotate as they should...and I can rotate the belt from the electric clutch to the deck.
Any ideas as to where I might look?
Thank you in advance...I appreciate your assistance.
Tatwo...:)
hlw49
Check the ground cable from the battery to the engine. It bolts on the starter. Also check the wires on the electric clutch to make sure they have not gotten cut by the motion belt and shorting out.
