2013 zee 2 electrical problems
Tcarp96
Cannot get it to turn over with the key. Every switch has been replaced: key switch, handle switches, brake switch, pto switch. Installed new wiring harness. Installed new solenoid. New battery. Will turn over if I jump the solenoid. Any advice other than shove it in a ditch?
Great little mower. Make sure the actuating lever is contacting the brake switch.
