Put old belts back on but had same problem could not push gas pedal down unless I removed top drive belt then center plate moves on variable drive and pedal works. If I put old belt back on again plate will not move like there is no room for plate to move or the plate hits the upper belt. I am A Master Mechanic I need help. Anybody know about how the plate works or something?
