2012 Bad Boy Extreme
Thanks again for your great input and support.
I agree with Scott on the carb bolt coming out fairly easy.......... Bert might have said something also....But I speed read sometimes LOL.....
Get the carb off and then drill a small hole in the broken bolt and then use a left handed drill bit and it should come out easy......
Plus Tard Mon Ami ~!~!
I just did a full service on my mower, oil, hydraulic, plugs, filters, etc. the mower ran fine for 20 hrs or so now when engaged and after mowing for a bit the engine starts derating and if I do not catch it and disengage the mower it dies and is hard to restart. However f I can get it disengaged it will idle really ruff for several minutes and then straighten out. I then can continue mowing for a bit then it happens again? Any ideas?
Are you saying that your mower is new and has only 20 hours on it ????
Kmott
Yes 20 hrs since service, thanks for the boot extraction advice
After you get that bolt out, check the gaskets and such then let us know and we can help you with your issue.........
Plus tard Mon Ami ~!~!
