Export thread
2011 lt 2000 drive belt replacement
#1
M
mwkelly
New member and Thankful I found this site. 2011 LT 2000 42" Mower. Model # 247.288841
Can anyone give me direction on installing the ( I call it the drive belt) belt running from the engine to the transmission. I have removed the deck and am stumped. Thanks Mike
#2
M
Mikel1
Not sure if this will help but figured I would post it up
How to Replace Most Craftsman Tractor Hydrostatic drive belts (LT200) - YouTube
#3
P
piochrobert
It's real easy, buy only mtd belt's they are 5/8inch or at least the long belt is. Take deck off, turn mower on right side,remove front pulley, then middle pulley to remove belt, then the rear belt off the trans, it can be forced off and back on, replace middle pulley with belt in place, then put belt on front pulley and slide it back on and install bolt. Then replace small belt and spring for tension. Took me a couple hour's taking my time. Run's like the first day i bought it. They wanted $194.00 at the shop, not worth paying to have done, do it yourself.
