Just wanted to check to see if anyone else is having electrical problems with any of their 300 series tractor. My 2010 X320 has been in the shop all most as much as it's been in my shed. At around 10hrs. it had 2 starters put in, which did not correct the problem. Then supposedly the whole electrical system was changed out in spring of 2011. Tractor ran fine for the summer then started acting up again in the fall. Spring of 2012 ran fine for a month then trouble starting again. Sounds like the starter's going , but they're telling me it's a ignition switch. Making it sound like it been the ignition switch the whole time. I'm at my wits end with JD.
Any help or opinions would be appreciated !!
