2008 Quadloop XWF2700
mft4play
I have a 2008 QuadLoop XWF2700, I replace the ignition and now it won't start. It cranks just won't fire up. Any tips to check would be greatly appreciated.
Thanks
Did you mount the tip over switch in the wrong position? It is the small round tube with two wires sticking out of one end. It mounts with the two wires pointing up.
