I have a Lt 1045. The battery is new, the starter is good. When I turn key on you can see starter jumps up to the fly wheel and tries to turn flywheel and it can't. Its seems like it has to much compression and it cant turn. Kept bumping the key and now it starts every time. I've been having this problem for awhile. Is it the valves sticking? I know it will happen again.
Can anyone tell me what they think it is that I need to do to correct this problem?
Thanks
Thanks
